sorry for the extremely nooby post but i completed my first build about 2 months ago, all was great, super happy with the results.
UNTIL...
i go to turn my pc on one morning and nothing happens. i check all the power plugs, all switched on. i noticed on the back of the power supply it was switched to the off position. when i turned it back no and turn the pc on...nothing, just a blue flashing light from the case.
so rather than spend hours buggering about with Antec warranties i bought a new one. A Thermaltake 550W ATX2.0. same specs as my last but beefed up to 550 from 380.
however my problem is this PSU has a big fan on the top or bottom of it which draws cool air in then exhausted out the back.
i cant work out which way it should be seated...fan on top where there is minimal space in which air can be drawn, or on the bottom which is full of hot air.
what does the web of knowledge think?
thanks
UNTIL...
thanks
) and pushed the power button.
