- 19 Aug 2008
- Cambridge
Greetings OcUK forum wizards,
I've been slowly building up a rig from scratch and I'm doing quite well with it. The one thing I'm not so sure about is power, so I thought I'd ask what would be a good power supply for my system.
I currently have a 600W PSU but it has no PCI express connectors so I can't use it with my new graphics card.
Current specs:
Intel Core 2 Duo E8400 @ 3.00 GHz (not overclocked)
4GB Corsair DDR3 1333MHz RAM (not overclocked)
Asus P5E3 X38 Motherboard
2xSATA HDD @ 7200rpm
1xSATA DVD-ROM drive
PCI TV card
4 additional fans
Currently with an old Radeon X300 SE in there so that I could set up Windows, a power meter shows the drain as constantly below 200W on load, and idles at around 120-130W.
The plan is to put a Radeon HD 4870 X2 in there, which I know is a beast for power consumption. I would also like to have the option to upgrade the CPU, add a VelociRaptor and possibly in the very long term add another X2 to crossfire.
Back in my day I know a 900W PSU would run a 4 GPU solution, but it appears times have moved on!
Any advice on:
-a budget PSU that will run the above rig along with the single 4870 X2
-a PSU with room for my specified upgrades
-is a modular PSU worth getting simply so that my case is tidier (I'm running an air cooled system)
Thanks for any help, appreciated!
mojomonkeyx
Current specs:
PCI TV card
4 additional fans
Any advice on:
mojomonkeyx
