power supply
Woah - thats some big PSU's, what are you running that needs that level of power?
For all but the most insane builds - this is the one to get (80 Plus Gold Certified).
It will definitely run normal SLI without breaking a sweat - personally I would not recommend going tri - SLI. The driver support is not there yet - so the scaling is awful compared to dual card SLI. Also, the ATI Dx11 cards are coming in October, spending over £500 on Dx10 graphics does not make much sense any more.
SLI'd GTX 275s gives you performance better than a GTX 295 - i'd say stick with either of them.
i don't ahve the money for a new case =[ which sucks but that power supply would defo fit, and what does everyone think of the new asus 295 mars, i personaly think the has beat everything out there and will dof or some time
Lol @ ASUS Mars.
If it didn't cost the same as three months rent it would be sweet. As it is, get a gtx 295 and wait for the Dx11 cards - they will be faster than the Mars and cost less than £400 when they appear.
You said in your other thread (why start a new one?) that you're gonna get two 275s. 1000/1250w is overkill for dual SLi. You'd be fine with the Corsair 850 or similar.
