I have just about finished getting all the bits ordered for my new build and i'm a bit stuck with the psu. I have a Corsair 430w V2 builder which should run everything fine but something is niggling in my mind to change it. I have done many calculators and came up with a max of around 380w inc the possible overclock and unlock of the cpu.
I have a few quid left if need be but funds are tight so if the psu is more than up to the job it can be kept.
My spec so far
AMD Phenom II 960T (Will hopefully unlock this to X6 and run around 3.6ghz all going well)
Gigabyte 880g micro atx board
HD 6850 Gpu
8GB DDR3 1600mhz 2x 4gb
3 sata HDD's
DVD Rom drive
Corsair CX430 V2
So will it cope is the question, I'm sure it will but my mind is dying on me tonight after hours of studying and at my age it's taking it's toll.
Cheers
My spec so far
HD 6850 Gpu
3 sata HDD's
DVD Rom drive
Corsair CX430 V2
Cheers
. All the calculators I have tried come in at under 400w even when the cpu is clocked to 4ghz and unlocked.
thats strong.
