10 Dec 2011 at 20:52 #1 chris408 chris408 Associate Joined 7 Dec 2009 Posts 102 what the best power supply to buy for £60 or under?thanks if anyone can recommend one
10 Dec 2011 at 20:56 #2 GTO656 GTO656 Soldato Joined 29 Aug 2011 Posts 3,068 Location UK Corsair http://www.overclockers.co.uk/showproduct.php?prodid=CA-048-CS&groupid=701&catid=123&subcat= Or XFX, this ones a bit over.but on weekly deal. http://www.overclockers.co.uk/showproduct.php?prodid=CA-003-XF&groupid=701&catid=123&subcat=1497
10 Dec 2011 at 20:56 #3 Ginger-Menace Ginger-Menace Associate Joined 9 May 2010 Posts 1,670 Location sheffield depends on what your set up requires, if you have an expensive set up i would recomend you dont skip on the psu, cheap high watage psu's is a no no
10 Dec 2011 at 20:56 #4 mickyflinn mickyflinn Man of Honour Joined 23 Mar 2011 Posts 19,187 Location West Side Cooler Master Silent Pro Modular 600W '80 Plus Bronze' Power Supply http://www.overclockers.co.uk/showproduct.php?prodid=CA-166-CM&groupid=701&catid=123&subcat= Whats your system spec ?
10 Dec 2011 at 20:57 #5 panyan panyan Soldato Joined 13 Mar 2011 Posts 7,484 Location Bada Bing GTO656 said: Corsair PSU is brlliant http://www.overclockers.co.uk/showproduct.php?prodid=CA-048-CS&groupid=701&catid=123&subcat= Click to expand... +1 very good
10 Dec 2011 at 20:57 #6 panyan panyan Soldato Joined 13 Mar 2011 Posts 7,484 Location Bada Bing mickyflinn said: Cooler Master Click to expand... ewww
10 Dec 2011 at 21:00 #7 mickyflinn mickyflinn Man of Honour Joined 23 Mar 2011 Posts 19,187 Location West Side panyan said: ewww Click to expand... lol
10 Dec 2011 at 21:01 #8 cmndr_andi cmndr_andi Soldato Joined 23 Apr 2009 Posts 11,973 Location Cheshire If you can find the exta £7, I would go with this one. Here is a review.
10 Dec 2011 at 21:27 #9 fowler002 fowler002 Soldato Joined 23 Oct 2008 Posts 5,042 whats the rest of the specs of your system and will you be running xfire/sli in the future?
10 Dec 2011 at 21:41 #10 Sasahara Sasahara Soldato Joined 12 Feb 2009 Posts 4,423 Hard to advise without knowing the spec. The best for under £60 are probably or a mid/upper mid range machine. PC Power & Cooling Silencer Mk III Series 400W http://www.overclockers.co.uk/showproduct.php?prodid=CA-012-PP& +12V@30A 360 W XFX Pro 550W Core Edition http://www.overclockers.co.uk/showproduct.php?prodid=CA-007-XF& +12v@44A 528 W.
10 Dec 2011 at 21:45 #11 jbloggs jbloggs Soldato Joined 4 Sep 2005 Posts 6,801 Location UK cmndr_andi said: If you can find the exta £7, I would go with this one. Here is a review. Click to expand... Either the above or the XFX Pro 650w (which is made by Seasonic)...
