Power supply
18 Oct 2002
Swansea
Hi guys please help ive been waiting for the case R3 to come in so i can buy my build (its in stock now) but now the power supply is out of stock , can you recomend me a similar one needs to be silent as possable , below is the build with the old power supply
Intel Core i5-3570K 3.40GHz (Ivybridge) Socket LGA1155 Processor (77W) - Retail £173.99
(£144.99) £173.99
(£144.99)
Gigabyte Z77X-D3H Intel Z77 (Socket 1155) DDR3 Motherboard £109.99
(£91.66) £109.99
(£91.66)
Cooler Master Silent Pro Modular 700W '80 Plus Bronze' Power Supply £79.99
(£66.66) £79.99
(£66.66)
Fractal Design Define R3 Midi Tower Case - Titanium Grey £69.98
(£58.32) £69.98
(£58.32)
Seagate Barracuda 7200RPM 1TB SATA 6Gb/s 64MB Cache - OEM (ST1000DM003) £65.99
(£54.99) £65.99
(£54.99)
Corsair Vengeance Blue Low Profile 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (CML8GX3M2A1600C9B) £44.99
(£37.49) £44.99
(£37.49)
Cooler Master Hyper 612S CPU Cooler (Socket LGA1366/1156/1155/775/AM3/AM2+/AM2) £32.99
(£27.49) £32.99
(£27.49)
Sony Optiarc AD-7280S 24x DVD±RW SATA ReWriter (Black) - OEM £19.99
(£16.66) £19.99
(£16.66)
many thanks
R3 does have some PSU size limitations.
TX750 fits but you need to feed cables through before mounting.
In mine the loudest fan is the TX650 (had TX750 in for awhile too) below 50% CPU... and I'm not the only one complaining about it.
An ultra-quiet, 140mm double ball-bearing fan delivers excellent airflow with exceptionally low noise levels by varying fan speed in response to temperature
is a lie. :mad:
Problem is i bought it and can't afford to replace with quieter now. :mad:
Sorry for the rant. Don't know what to suggest as too frustrated to even look.
no , no cross fire or sli , what would be ample for the system plus i need to get a graphix card later on
A solid ~400W unit will be more than enough if you're running just one card.
http://www.overclockers.co.uk/showproduct.php?prodid=CA-056-BQ&groupid=701&catid=123&subcat=
http://www.overclockers.co.uk/showproduct.php?prodid=CA-006-XF&groupid=701&catid=123&subcat=
The XFX Core 450W is probably the better choice, but you can make a good case for the BeQuiet (it does live up to the name).
Edit: actually scratch that - the XFX gets loud at high loads, you'll want the BeQuiet 430W.
