Power switch
15 Apr 2011
UK
is it possible to buy a replacement power switch for a pc case with an extremely long cable or is it possible to buy extensions for theses cables ?
just to make it clear which wire i mean…
I do believe you can buy extensions, or you could break the existing wires and patch an old wire in between to extend your own. Either solder or twist bare ends would be fine as the circuit carries very little load.
A US based PC modding store sells the extension cable, but as tealc suggested, doing a bit of soldering is a much cheaper way
