I have just built up the following and when I switch it on everything has power but I am getting no output on the inbuilt graphics.
I have
Coolermaster 460W PSU
Gigabyte GA-M750SLI-DS4
AMD Phenom 9850
2x2gb Crucial DDR2 800
2x500GB Seagate drives
I have connected all the fans, the 20 pin power and the 4 pin next to it then there is an 8 pin connector but I only have 1 4pin connector that will fit in the required holes the other 4 pin is different and if I plug in the 6 pin it just doesn't boot. There is power the hard drives spin up but I get no output on the screen. I'm going to try a different moinitor but I'm thinking I need a different power supply that has this 8 pin connector am I right as I don't want to keep buying things that don't fix my problem.
Any help appreciated
Thanks
Phil
I have
AMD Phenom 9850
Thanks
Phil
