Power usage. In standby
9 Feb 2011
Just checking my power meter and i use about 100watts, when nothing is on
(So background stuff of router, alarm, 2 x clocks, xbox in standby, 3 tvs in standby, wii in standby)
Whats everybody else "off" average
Things like your boiler will still be using power even if they're not 'on'. Fridge drinks the juice still even if the compressor isn't running.
HTPC? Sky boxes? Chargers? Printers? Immersion heater?
Is there potentially a spur going to a part of the house/flat that you're not aware of?
I don't know what my usage is but the only things permanently on are:
fridgefreezer
boiler
house alarm
Router/modem
Clock radio
Electric toothbrush
Everything else stays off until used
Try switching them off one by one to see how low you can get the number. Managed to get my flat down to 20watts, think the fire/burglar alarms are the rest.
Most times I can't get it below 295 - 345w. It's only two freezers and one fridge through the night plus the boiler pump/heating. Most of the time into the evening it's 995 - 1.19KWatt.
If you leave a 1m extension chord plugged in and switched on but with nothing plugged into it, that's costing you about 5 picowatts, and that's the ones without the little red light!!
