I just bought a PDP Xbox Controller, and it's awful. The LB & RB buttons only work if you press them right at the edges. If you press them near the top, the controller isn't built so you can press them down at all. The only time they'll press down is if you press them right at the edge.
I'm just wondering if the PowerA Enhanced controller will be the same, or can I press the LB & RB buttons anywhere along the button, including near the top?
Here's a couple of screenshots to show what I mean. The first is the PDP controller I bought, and the second is the PowerA Enhanced controller I'm planning on buying. Also, I know the easy solution will be "Buy an official controller" but that's not an option at the moment unfortunately.
