Powercolor Red Devil RX 480 8GB Overclock Help?
27 Nov 2012
Interested in overclocking my 8GB Powercolor Red Devil RX 480 GPU, but not sure where to start,
I have overclocked m old 7970 before pretty easily with GPU Tweak, but everything is locked out on it with the RX480, I can only change fan speed
Whats the best way to overclock this GPU now? which program etc?
Thanks
Probably best to use Wattman (assuming it's not buggy for you). AdoredTV did a good tutorial on it.
I have the same card and clocked it using Strix i get 1390 core and 2200 ram.
Its pretty easy install, move sliders and test - repeat until stable and happy
That's interesting. I have the same card and never heard of Strix apart from the ASUS range (guess it might be part of this just software).
Does it mean the card's fans are at max all the time and do you see much benefit in games?
Cheers.
