Hi,
Just bought a new machine a few months ago
https://forums.overclockers.co.uk/threads/time-for-a-new-gaming-pc-advice-needed.18872399/
It seems to be mostly working well with most games. Had a few crashes though especially with Modern Warfare (seems to be improving with updates). I often get micro stutters and slight pauses even on older games such as AC Unity and Battlefield V. Had artifacts in MW in single player (On certain character's faces occassionally)
The case exhausts also seem to get quite hot and the temp on card has gone up to slightly above mid 70 at times. Not sure whether that's normal
I have some speculative ideas...
1. Might need new case fans. There is a bit of play in one of the fans and the top of the case gets quite hot.
2. I use two power cables to the card ; Should I be using just one ? Can they be a different brand ?
Cooling is as follows....
Case has two exhausts, large one at top of case, one at rear top. One inlet lower front. Power supply at base of case (right side up). CPU fans both face towards the rear....
I'm using Radeon Driver 20.4.2
I use a Display Port cable with my Dell2311H Monitor
What can I do to get the most from my card and make it run at it's best ?
Thanks for your help
Viper10
- MSI B450-A PRO MAX (Socket AM4) DDR4 ATX Motherboard
- AMD Ryzen 5 3600 Six Core 4.2GHz (Socket AM4) Processor - Retail
- Patriot Viper Steel 16GB (2x8GB) DDR4 PC4-28800C17 3600MHz Dual Channel Kit
- Powercolor Radeon RX 5700 XT Dual Fan 8GB GDDR6 PCI-Express Graphics Car
- Gigabyte 1TB M.2 PCIe x4 NVMe SSD/Solid State Drive
- Seasonic Prime Ultra Snow Silent 650W 80 Plus Platinum Modular Power Supply
- Arctic Freezer 34 ESports Duo White CPU Cooler - 2 x 120mm
Viper10
