Thanks m8
Where does the Powercolor RX550 2GB - AXRX 550 2GBD5-DHA/OC fit in??
PowerColor Red Dragon Radeon™ RX 550 2GB GDDR5 OC V2
https://www.powercolor.com/product?id=1498033015#spe
Graphics Engine AXRX 550 2GBD5-DHV2/OC
Video Memory 2GB GDDR5
Stream Processor 512 Units
Engine Clock up to 1190MHz with boost
Memory Clock 1750MHz x4 (7.0Gbps)
PowerColor Red Dragon Radeon™ RX 550 2GB GDDR5 OC V3
https://www.powercolor.com/product?id=1513231070#spe
Graphics Engine AXRX 550 2GBD5-DHA/OC
Stream Processor 640 Units
Memory Clock 1500MHz x4 (6.0 Gbps)
Thanks for that info.That second card is a baffin core while the first is lexa. The second one will unlock shaders/compute units and also overclock like a monster. Basically the second card is an rx560.
In theory it's as easy as flashing either an RX460 or RX560 BIOS which would get you either 896 or 1024 shaders
BIOSes can be found here e.g.:
https://www.techpowerup.com/vgabios/193464/powercolor-rx560-2048-170508
Thanks again
So just flash the cards BIOS with this one???
