LoadsaMoney said:Definately worth it, theres even ppl happy with the x1900 who have gone from 2x GTX's in SLi, its a cracking card.![]()
@Seirrah, any manufacturer will do, as they are all the same cards, as they are all based on the referance design, only differences will be the pic on the cooler on what software you get.![]()
got 11800 in 3dmark05. went from a x850xt and im chuffed
though my x850xt is a HIS and came with an artic cooler rather than the stock heatsink.SpudMaster said:all sliders to the left? you mean image quality settings in drivers? if so all was set on max quality but aa and af set to application controlled. 3dmark set at its default settings. and my cpu is an opty 170 at 2.8ghz.
No probs AnastieByte, will get them measure after my teathough my x850xt is a HIS and came with an artic cooler rather than the stock heatsink.
the_box said:any ideas as to why im not reaching 11k on 3dmark 2005?
