- 26 Jul 2010
- Wiltshire
Purchased (new) a day ago, it's artifacting and rebooting
Installed with the appropriate precautions i.e. static strap and making sure the card is seated and not touching any capacitors etc, fresh Win 10 installation with latest drivers. Output is via HDMI to Samsung monitor which was fine with a R290/1080, I've tested it on my HDTV and it's no different.
I've tried various display modes, swapped cables (both twin 8pin power and the HDMI) switched which power rail is used for the twin eight pin power cables etc etc. I've tried the different bios settings too, the only thing i can see is that there is a row of LEDs on the back of the card (above the LED logo on the cooler) as as you look at it in situ and the last to the left but one is lit? - see picture.
I've no idea what this means as the documentation is woeful
Cooling fans are working.
Specs are Asus sabertooth Z87, 4770k, 1300w EVGA psu that can handle quadfire/sli so that shouldn't be the issue.
Stumped! Apart from a duff psu that springs to mind I've rarely had an issue with hardware, certainly never with new stuff.
Artifacts
Cooling fans are working.Specs are Asus sabertooth Z87, 4770k, 1300w EVGA psu that can handle quadfire/sli so that shouldn't be the issue.
Artifacts
