Powered Hub for Naga Epic Mouse
25 Jun 2013
I am trying to find a hub that is always powered so I can dock my mouse when not using the PC so it can recharge. No point having a wireless mouse if you have to keep plugging the cable in ;)
Does such a thing exist?
You should be able to use the USB dock even when the pc is turned off as power should always be supplied to the motherboard USB ports.
Does that help?
Mine aren't powered when the PC is off but at the moment I am using a laptop.
The dock uses the USB power to charge the mouse.
