I have a usb 1tb and 2tb western digital hard drives in my PS4,can't see any difference between the powered one or usb.Hey guys,
What would be the best option for extra storage on my One X? Is there any difference?
Is a powered HD likely to fail any sooner etc.. than a portable one?
Cheers.
portable for me, 5TB Seagate for the X and 4TB WD on the Pro. Easier to hide away and two fewer power sockets needed.
Real world gaming use the difference is minimal as the 5400RPM internal drive uses the internal flash ram to cache the data. But the external drive does not get cached. You could probably put any cheap SSD or HD into an external USB3.0 enclosure & the difference for most games will be minimal. Same as SSD vs HD there is little difference apart from some save games load faster on SSD.
