- 22 Mar 2009
I just set up Prolimatech Megahalems cpu cooler and attached 1 x Delta 120mm Focussed Flow Fan (3 pin) that plugged into cpu pin header. I had attached 38mm fan clip x 2 that hold Delta fan from the bottom of the cpu cooler that blow airflow upward to the big exhaust fan at the top of my Antec 1200 case. I had set cpu fan as (voltage) and enabled in the bios.
At idle, the fan is quiet at 1700rpm and when under stress 4Ghz and the fan spin at 2700rpm (not 4000rpm) and got very nice cooling temperature on north bridge at 39C, cpu temp 37C and motherboard temp at 31C and core temp is idle at 29C, 27C, 29C, 27C and under stress at just 55C, 55C, 53C, 53C with an hour stress of linx. That's so amazing temperature with my room temperature of 23C! Why didn't I do it in the first place ?
However, I was worry about two things is: is placed heavy delta fan under bottom of cpu cooler is bad idea due to heavy weight? and is the cpu set to voltage reduce from 4000rpm to 2700rpm could burned out pin header cable ?
Okay, 4000rpm is very very loud, 1700rpm very quiet, 2700rpm is medium and fair (not too loud but could hear massive huge airflow blowing out)
That's the fan I use here: http://www.overclockers.co.uk/showproduct.php?prodid=FG-003-DE&groupid=701&catid=57&subcat=4
