Powering 3090: Use 1 vs 2 PCIe 8 pin PSU Sources
22 Oct 2012
Hullooo chaps and occasional chapettes. I'm running a 3090 from a Corsair HX-1000 PSU.
The standard 8-pin PCIe cable from the PSU has two 8-pin plugs attached to it. However out of caution as I'll be pushing 400w I've run a separate 8-pin out of the the PSU, so effectively my graphics card is powered via two separate 8-pin plugs from the [EDIT] power supply.
Is this redundant and a bit silly? Always keen to reduce cable clutter if I can.
Nothing redundant with the Ampere cards - they can pull some silly levels of transient power in spikes - I'd rather have the reassurance personally.
This is the recommend cable setup for a 3090 anyway?
3090's transients are near 600W level and overclocking likely pushes those further.
Well that settles it even more securely, cheers. Out of interest where are these instructions from?
There have been actual cases here on UcUK forum with use of single daisy chained/split from GPU end cable causing problems solved by switch to two separate cables.
Cheers all. For now will use the dual 8-pin to 12-pin setup, but have also ordered a custom white modDIY white dual 8-pin to 12-pin cable to simplify things a bit down the line.
