No idea if you can with the NZXT leds. Might work (some other types do), just wouldn't be able to use brightness options on the sleeve, or the brightness and modes options on the Hue.
It has its own brightness settings and power switch it goes in an expansion slot in the case. It has 3 pins on it it doesn't connect to s 3 pin a 3 pin connects to it.
