- 19 May 2014
A bit of an odd one…
I’m trying to build a cooling solution for something at work consisting of 4-6 Noctua industrial 3000rpm PWM fans.
I’ve bought a Molex to 4x 4pin fan splitter and a 12v Molex power supply.
Plugged it all together and nothing. Tested the fan and the Molex to fan splitter in my PC and that worked fine so I think there’s an issue with the power supply, though I’m not sure whether I just bought the wrong thing or whether the power supply is faulty.
The pins on the power supply are correctly laid out, and the power supply can either do 5v or 12v at 2amps. The seller of the power supply suggested the 2amps might be too much for the fans but I don’t know enough to know if that’s true?
So, I wondered if anyone here could advise what I should buy in order to power the fans? Am I better buying a proper ‘external’ fan controller and then finding a way of powering that?
Any advice would be hugely appreciated.
