Powerline adapter help
18 Nov 2011
London
Hey guys,
I bought a pair of On networks 200mbs powerline adapters the other day.
Just set them up, on into my virgin hub and on into my computer upstairs.
The power light is green, the connection to ethernet light is green but the powerline connection light is red??
In the manual it says if this light is green, then it is connected. If it is off, then it isn't.
I do get a connection though it, all be it >1mb on a 60mbs line.
Any ideas on how to improve them?
Ok ignore all that!!
The light was red because it was saying its receiving signal, just not very well.
I had it on an extension lead which pretty much caused the problem, plugged straight into mains and now im getting good speeds, faster than wifi.
Tasty.
I had a 'gigabit' pair, their actual speed was around 10MB/s which is slower than a 100Mbit connection.
Ditched them and drilled a hole in the ceiling instead, now I have gigabit LAN ~80-90 MB/s, limited by my hard drives
