powerline adaptors how do they work
31 Jul 2006
Belgium land of chocolate
Ok I'm looking into getting these however I'm not sure they will work properly.
Dodgy european wiring in my house. So tell me is there anyway I can check if it will work before buying?
What's users experience with these plugs?
I have a modem in the garage hard wired to my router in the living room, I take it I just connect the router to the plug in the living room and then plug in the 2nd pluc and connect to my device where ever I want to place my second device?
Would this be a correct assumption?
That is correct,the signal pass's through the internal house wiring to the 2nd plug.
Very very good items these plugs and save a lot of hassle running cable or wireless.
ok gonna bite the bullet they aren't expensive so can always resell if they don't work.
