Powerline and high latency
Capodecina
Permabanned
31 Dec 2003
Barrow-In-Furness
Evening all,
I've had a Powerline setup for a while and started gaming again recently and my ping is 60+ constantly, and pretty inconsistent.
Brother using wireless is consistently lower than me.
Do you think it's my roughly 2 years old powerline kit being poor, or is that the nature of the technology? (It's NETGEAR HD something, will dig out the model number)
It was the same in my old house and i've recently moved.
I don't see how powerline/homeplug technology should be slower than wireless.
My setup:
PC --> Router 1 --> Homeplug --> Router 2
These are the results of me pinging Router 2 from my PC.
Code:
C:\Users\Blah>ping 192.168.1.254
Pinging 192.168.1.254 with 32 bytes of data:
Reply from 192.168.1.254: bytes=32 time=4ms TTL=63
Reply from 192.168.1.254: bytes=32 time=6ms TTL=63
Reply from 192.168.1.254: bytes=32 time=5ms TTL=63
Ping statistics for 192.168.1.254:
    Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
    Minimum = 4ms, Maximum = 6ms, Average = 4ms
Brothers using wireless and getting a 40-50 ping in games, mines going from 50-90, with an average about 65ms
I've got PC > HDXB101 > HDXB01 > Router
Reply from 192.168.1.254: bytes=32 time=4ms TTL=64
Reply from 192.168.1.254: bytes=32 time=37ms TTL=64
Reply from 192.168.1.254: bytes=32 time=82ms TTL=64
Reply from 192.168.1.254: bytes=32 time=3ms TTL=64
Reply from 192.168.1.254: bytes=32 time=6ms TTL=64
Reply from 192.168.1.254: bytes=32 time=25ms TTL=64
Reply from 192.168.1.254: bytes=32 time=100ms TTL=64
Reply from 192.168.1.254: bytes=32 time=31ms TTL=64
Reply from 192.168.1.254: bytes=32 time=580ms TTL=64
Tried changing ethernet cables, changing the plug socket used, changing ethernet port on my PC.
Reply from 192.168.1.254: bytes=32 time=22ms TTL=64
Reply from 192.168.1.254: bytes=32 time=19ms TTL=64
Reply from 192.168.1.254: bytes=32 time=20ms TTL=64
Reply from 192.168.1.254: bytes=32 time=15ms TTL=64
Reply from 192.168.1.254: bytes=32 time=99ms TTL=64
Reply from 192.168.1.254: bytes=32 time=71ms TTL=64
Reply from 192.168.1.254: bytes=32 time=90ms TTL=64
Reply from 192.168.1.254: bytes=32 time=23ms TTL=64
Reply from 192.168.1.254: bytes=32 time=30ms TTL=64
Reply from 192.168.1.254: bytes=32 time=74ms TTL=64
Tried the powerline equipment with my new PC and it's still spiking like crazy when just pinging even my local router.
Can't run cat5, but would rather not buy a wireless adapter.
However I am a bit concerned about spending again on new Powerline stuff and having the same problem.
Any last ideas?
Not that I can think of.
Tried using different sockets on the opposite side of the room, swapping the ethernet cables etc. Tried downloading the configuration utility and changing the settings of that but it made no difference whatsoever.
Any final thoughts guys?
Might just order a new Powerline kit and hope it works, if it's still high then I guess i'll just have to sell it
I cant give any advice, but my generic powerline plugs from the rainforest are fine, I get about a 40ms ping all the time and It did at my old house. It may be your powerline plugs.
I've quite far away from the router and after reading comments I suspect the signal will be going through a circuit breaker before reaching where I am. People have mentioned lots of loss/signal degradation as a result of this.
Hmmmm :F
Might be worth getting some gigabit ones as they are likely to have better tolerances? As you say the circuit breaker degrades the circuit a lot I believe.
An openreach engineer told me the newer powerline adaptors don't have any issues with the circuit breaker because they use the earth wire instead of the live. Whether that is true or not I don't know but my XAVB2501's work fine over two floors.
Code:
Reply from 192.168.1.254: bytes=32 time=5ms TTL=64
    Packets: Sent = 19, Received = 19, Lost = 0 (0% loss),
    Minimum = 3ms, Maximum = 5ms, Average = 3ms
That looks great, i've just gone for it an ordered two of those. Pretty expensive!
Hopefully they will give the same performance as you've had otherwise I guess i'll just have to try sell them.
They are a bit pricey but I could only find good things about them, thankfully they worked out OK.
Got my fingers crossed for you :)
Cheers, i'll post the results this afternoon.
A quick ping to the local router once I get home will be all that's needed :)
Just been reading this with interest.
I have D-Link homepluge DHP-301's, my office pc's are connected to a router, Belkin N1 view, then to dhp-301, then downstairs I have 3 other DHP-301's, one for the WD Live, one for a laptop the otherh connects to the broadband router.
At the moment the one in the office is plugged in and on and also the one downstairs to the router, my ping is as follows:
Pinging 192.168.2.1 with 32 bytes of data:
Reply from 192.168.2.1: bytes=32 time=4ms TTL=63
Reply from 192.168.2.1: bytes=32 time=81ms TTL=63
Reply from 192.168.2.1: bytes=32 time=3ms TTL=63
Ping statistics for 192.168.2.1:
Minimum = 3ms, Maximum = 81ms, Average = 23ms
Am wondering what could cause the ping to be so high for one of them? If I repeat the exercise usually three of the four are 3 or 4 ms but one is very large.
regards,
Matt
New ones wok a treat, results below!
Thanks for the recommendation :)
