Hi,
I recently upgraded my VM internet to the 350 package, wired to the router I can get 370-390 speeds and even wireless on 5G on my Iphone X I can pull 350..
Ordered a newer set of Homeplug ethernet as my previous were older and 600mbps ones I figured I'd try some new ones to try get the full potential. It's all connected up fine etc however it seems to max out at 150 is there a reason for this? Am I doing anything wrong?
The plugins I have are
AV1300 Gigabit Passthrough Powerline ac Wi-Fi KitTL-WPA8630P KIT
Result from ethernet plug -
My devices show connected as 550-600 on the TP-Link app too
Any wisdom guys?
Thanks! Using it for Plex with Nvidia shield, laptop etc for 4K streaming ( which it does but it did that with my old setup at 150 )
- AC1350 – Dual band Wi-Fi with combined speeds of up to 1350Mbps
- HomePlug AV2 – Provides ultra-fast powerline transfer speeds of up to 1300Mbps
- 2X2 MIMO – Establishes multiple simultaneous connections for you to enjoy higher powerline speeds and greater stability"
Any wisdom guys?
