Hi,
I've finally had my Infinity connected today and i'm currently trying to find the right solution to connect everything up.
My master phone socket was in my front room so the engineers fitted the kit there. The only issue is that my PC is upstairs so since I have a preference to use a wired connection i'm currently using a borrowed set of Comtrend powerline adapters (i believe they are rated at 200mbps).
i'm not amazed at the speeds i'm getting right now, but its early doors.
I'm trying to decide whether to try and find an ethernet wiring solution or get my hands on some TP-Link AV500+ adapters.
is there a way i can measure the effectiveness of the current adapters i'm using?
would i notice a difference if i went for the above TP-links?
