- 29 Jul 2004
- Glasgow/The Netherlands
So im looking to get some Powerline/Homeplug adaptors, just a quick question first on what I need to buy.
At the moment I have it all wired but we are changing the computers to a different room, as the wires are setup so it goes through a hole inthe wall to the current room, i was thinking Homplugs would be a good idea for when we move them to the new room as I dont want to bore any more holes in the walls.
Would this work?
Modem --> Wireless router --> Homeplug --> other Homeplug --> switch to PC's
Also if I wanted to add an XBOX360 in another room, would I only need another adaptor?
If that setup is ok what would you guys recommend for the homplug adaptors?
Thanks in advance
Would this work?
Thanks in advance
