So I am currently running off of a wireless signal from a G router (can't change) and my connection is less than great and am therefore looking at alternatives.
Obviously it would be ideal to run a cable from the router to the pc but that means ripping up the carpets/drilling through walls/hassle and I am therefore looking at some of the power line adapts where you simply use the electric system to route the network. As I do a lot of gaming ping speed and network stability is of paramount importance and is the main reason for me trying to switch from the wireless, would these homeplub style adapts offer better performance than a wireless signal?
I live out in the country side so the internet access itself isn't ideal - 40ms ping, 1.9mbps DL so there is even more reason to try to squeeze out every little bit!
Lastly, if I were to get a wired connection by any means - would it be worth getting the bigfoot killer 2100 NIC? I have read mixed reviews about it but frankly I use the net so much even a 3-5ms ping speed increase with some added stability would be amazing!
/madals
/madals
