powerline / network issues unidentified network
10 Nov 2011
Telford
ive been usingtrednet 500mbps powerline kitfor about a year.
Today i just wanted to test if this usb wifi dongle worked so plugged it into my pcconnected to net worked fine.
Removed it and uninstalled drivers now my powerline kit doesnt appear to be working.
All i'm getting is unidentified network.
Ive tried resetting all ip settings, forcing addresses resetting router.
I have just moved the powerline kit downstairs into the same room as the router is in and this is on the wifes laptop and its getting exactly the same problem from the powerline kit now unidentified network.
Any ideas?
Have you tried repairing them with the router?
Have you used them in different power sockets in the same room, to rule out problems with wiring? Obviously it will be on the same ring-main so that isn't the issue.
Is there anyway too de-install the plugs if they came with software?
