Powerline networking - 200Mb or 500Mb
26 Jan 2005
In........cognito
I'm looking at getting some of these now that wifi is so overcrowded.
The main question is, are the 500Mb ones worth the extra? If I was guaranteed to get 350-400Mb I'd probably pay the extra.
Also, do they work from a downstairs ring to an upstairs one? Sorry if these are stupid questions but it's new tech to me.
Thanks. :)
200Mb are 100Mb and 500Mb are 250Mb in perfect lab conditions. The speed is listed as both directions at the same time (full duplex mode)
So in reality a 200Mb plug will give approx 50Mb speeds and a 500Mb plug will give 120Mb.
They should work across rings. however your mileage may vary depending on your fuse box/rcd etc. The same goes for the speeds obtainable.
Thanks for the info. Sounds like it's worth getting the 500Mb ones then as I want it for file transfers to/from the network drive.
Anyone got any experience with the T-link 500Mb ones?
