Hi guys, looking to buy one of these units you plug your router into then into a wall socket. I would also like the units to have wifi. I have a virgin up to 152mb connection. The router/modem will be downstairs and the PC up in one of the bedrooms. Can you please suggest something that's really good! but not too expensive
Thanks.
Edit: just to add, I do a lot of gaming online so didn't really want to have the PC using wifi. Want the cable from the wall socket plugged into the motherboard connection.
Thanks.
