Hi all,
I've been trying to rig up an internet connection to an outside office/studio (containing two computers) using powerline adapters.
The main house gets a solid 20Mbps download speed which is fine. However, the powerline signal has to pass through two fuse boxes and some pretty dubious wiring before it reaches the outside office, and resultant download speeds are between 5-200kbps in the studio (often the lower end of that). Obviously this is pretty crappy and disconnections are also frequent. I've gone through the usual routine of switching off as much heavy duty electrical stuff as is practical.
I'm currently only using 200Mbps adaptors. Would upgrading to 500Mbps be likely to make any difference, or should I give up and look at drilling holes and running some ethernet cable?
