- 13 Jan 2004
- UK
Can't decide between a Netgear HDX101 or a USB Wireless Adapater such as the WN111. Are the speeds from a powerline decent enough?
Depends on your use to be honest, obviously powerline is no use for connecting a laptop but wireless isn't the best choice for connecting a desktop which never moves to a router at the other end of the house.
If you plug your laptop into the mains, then you can use a powerline adapter as well, and gain from the excellent connectivity![]()
