Powerline Queries!
Sui
Sui
24 Sep 2005
Brighton
Powerline Query!
Basically, apart from my room wireless is fine, with me as I'm a bit further away I get dropouts etc and it's getting pretty annoying. Just wondering if I were to just get a set of 2 powerline adapters, would this affect the existing wireless network in anyway? :E
Shouldn't do as long as the router has a hub/switch built into it. Put it this way its the same as plugging your computer directly into the back of the router, if you can do that without affecting your wireless then you will be fine.
