powerline query.....
28 Jul 2003
South Wales
I currently have some old Netgear powerlines (around 5-6 years old). I want some quicker devices and have been looking at the TP link AV500 sets. If i bought the GB ones, but then wanted to extend further but didn't need the extra speed, would the 500MB's ones work with them? Can i mix speeds?
I'm tempted just to go with the 500MB's ones anyway. I want them to connect to my server in my spare room for HD streaming.
I believe if you mix speeds everything runs at the slowest speed (or even slower). 200MB's shoud be fast enough for HD streaming so 500's should be fine.
I'm having exactly the same dilema, I've got a couple of 200 home plugs at the minute but want to add some more and I'm loath to go with the slow ones but too tight to upgrade them all!
Considering the 500's are around £25-30 a set, I may aswell plumb for those? I'm assuming the GB port on them is pointless as the 100mb ports shouldn't be a bottleneck with these?
Would give the GB ports a miss, 500's seem to be the market sweet spot at the minute
Drill holes, lift carpets, fit ethernet ports.
Cheaper and 1000x better!
The homeplugs do the job take a 1000x less effort and are 1000x easier to get past the wife than destroying the house! I know which I chose, I would only consider cat5 if I was rewiring or redecorating the whole place.
Avoid the tp-link ones... I and others have had problems with them cutting out randomly.
