Powerline Question
3 Aug 2003
Plymouth, UK
Probably very easy for someone to answer this.
Will a powerline network connect if the two adapters are plugged into seperate ring mains?
Reason being is that trying to get connection to all stuff downstairs from router/modedm upstairs and was looking at this as an option instead of running cables. Have tried wireless, but this is rather flakey, so need a more robust connection method.
Cheers
Paul
Yes it will with household wiring as the ring mains are normally connected at the consumer unit. May be an issue if there was say 2 different meters or if your wiring is appaling (in which case get if checked).
I had the same issue 85mbps max connection speed was reduced to 62 ish. But worked fine and stopped my wifi unrelaibility.
