 - 7 Oct 2008
 - Birmingham
At the moment using a netgear DGM1000 on VM ADSL.
I don't get a very good signal (basically none existent) upstairs in my room. In my room I have my 360, my PC and occasionally my netbook/phone. I can't run a wire up to my room or drill holes as it's rented so that's out.
So, do I get powerline adapters and then a switch in my room to connect the 360 and the PC to or a better router?
I intend on gaming on my 360 or PC quite a bit, never both at the same time. If I'm on my xbox my PC will probably be browsing so I assume a cheap switch (10 quid ish) would be able to handle this? With the powerline adapters I can then just go sit downstairs to DL something big on my phone and then either connect my netbook to the switch or just deal with the slow connection as I'd only use it browsing in bed.
The other option is buying a better router than my current one. Which would give a better outcome? Bearing in mind up to five other people and myself (six in total) could be connected to the router at the same time vs just me on the powerline adapters.
