Powerline to Wifi (booster)
23 Jan 2006
Afternoon all!
I have a powerline setup in the house (RJ45 only) for desktop machines and am looking to add a couple of wifi boosters for the hard to reach places. There seems to be a lot of cheap extenders that plug in but are they just repeaters?
example:
http://www.overclockers.co.uk/showproduct.php?prodid=NW-102-TP&groupid=46&catid=1837
Can anyone recommend something simple to help. The powerline units are cheap D-Link but work very well...just looking for a plug in powerline extender.
Thanks in advance
Lawrence
The item linked is just a wireless extender.
For Powerline based extenders look in the Powerline section. Something like the TP-Link TL-WPA281 would probably suit, but I haven't personally tried one.
Although it isn't as tidy I prefer more tradition access points (or wireless routers configured as APs). You can then connect them using standard Powerline adapters (or preferably a cable).
Hi Brem, thanks for the response.
I have tried using a 2nd router with the powerline and have created 1/2 a useable network, 1/2 a broken one and most of the wireless devices get confused so I was trying to simplify.
I will give something like the WPA281 a go and report back
thanks!
Is there a way of getting an area in the home that would get a decent signal to everywhere?
The reason for saying is, I ran this setup for a while and it was perfect.
I've only changed as I purchased more powerlines for the devices that
really didnt need wifi, ie Raspbmc pi and a few smart tv's
Router 1, connected to master socket with all fancy things turned off inc Wifi.
Router then connected to a powerline beside it.
Placed the second powerline in a good spot in the centre of the home
Connected second router to the second power line.
Sorted
