Powerpoint 2007 - navigating using buttons
28 Feb 2006
Wimbledon
Hi all,
I'm making a powerpoint presentation that will be used on a touch screen computer, so the only way to navigate will be to press buttons which hyperlink to corresponding slides. The only problem is that the slides contain different information based on a product, I'll try outline it below:
Main Screen - select product 1,2,3,4 etc.
Product 1 screen - 8 different tabs with information about the product, you can press the tab to navigate to that page, so all tabs must hyperlink to all the other tabs.
So the way I have set this up for product 1 is having the 8 tabs at the top and 8 different pages for those tabs (tab 1 page, tab 2 page etc.) and each tab on each page links to each page.
This works great, but if I am putting in say 12 products, this means 12x8 pages which is a lot.
Whilst I don't mind a lot of pages, it will take ages to do the hyperlinks between each tab, so does anybody know of a way to copy all of my current slides, and then paste them as, lets say product 2 slides, and the hyperlinks will all update to being the correct hyperlinks for product 2, or will I have to reset all the hyperlinks manually?3
Hope this is explained well enough!
