PowerPoint 2010 Text help
Don
23 Oct 2005
North Yorkshire
Hi guys,
I've created a presentation in Power Point 2010 and am just wondering how to edit the slides.
I basically don't want all the text on the slide at once, I want to manually select when it comes in. So when I press the right arrow key a certain of text will pop up on the slide, when I've finished presenting that text, I want more to come in on the same slide.
I've tried right click on the text boxes looking for such settings but can't see anything, can anyone point me in the right direction?
Cheers
Highlight the text you want and select the animation you need for that text.
each time you do it, there is a little number which appears. This indicates the ordering.
you can select the time and trigger at the top right of the ribbon from memory.
