Powershell get-hotfix and export-csv
8 Mar 2005
London, UK
I'm truly struggling today;
Feeder file with list of servers
Prompt for KB<numeric>
Checks whether HFB has been applied and reports installer and date details and then exports to simple CSV.
It's pretty much a simple one-liner but I'm going around in circles with the export!
Currently
Code:
Clear-Host
$Machines = "C:\windows\servers.txt"
$Patch = "KB2922229";
#$Patch;Read-Host 'KB<numeric<>'
$Computers = Get-Content $Machines
$temp = $null
ForEach ($Item in $Computers)
$temp +=,(Get-Hotfix $Patch -ComputerName $Item | Select PSComputerName, HotfixID, Description, InstalledBy, InstalledOn | sort InstalledOn)
$path = $temp | Export-Csv 'c:\output.csv'
OK, so this dumps out what I need, however I would like to include rows where the patch isn't installed and also where the server is unavailable/non-reportable.
Cheers, Paul.
You're exporting the file each time it loops.
You could look at adding -NoClobber and -NoTypeInformation as switches on the export but the better way to do it, imo, would be to compile the results into another variable and then sort/export that at the end.
So something like....
Code:
Clear-Host
[array]$Results = $null
	$Results += Get-Hotfix $Patch -ComputerName $Item
$Reults |
		sort InstalledOn |
			Export-Csv 'c:\output.csv' -NoTypeInformation
... should work.
No thank you. I need the all assistance I can get! :)
I also need to include where the patch isn't installed and where the server is unreachable (for whatever reason).
Cheers, Paul.
