PowerShell gurus - me again!
28 Sep 2008
Britain
Chaps,
I need to remove a large number of users from multiple groups. ie, for 100 users that are in 6 groups (all 100 users are in the same 6 groups), i need to remove them from those 6 groups.
I'm thinking something based on OU (as all 100 users are in the same OU).
Maybe there's a way that doesn't involve PowerShell??
Here's 1 way: http://technet.microsoft.com/en-us/library/ee617242.aspx
So you could create 2 files containing the user list and group list, read them into the powershell script and then do a nested loop. This would make your script reusable in the future (all you would need to do is edit the list files for users and groups).
Example pseudo code:
Code:
foreach (group)
	foreach (user)
		Remove-ADGroupMember <user> <group>
Of course, remember the -whatif parameter for testing it out.
