Good afternoon everyone,
Im after a bit of help with a script im trying to get working.
The script in itself is designed to create an Outlook signatures based on a users AD properties. Its based upon the template MS have provided.
The script itself, i have working how i want it to as an end result, however ive got a few issues/problems that i could do with some input on.
-- Unless I enable registry editing, the script wont run in its entirety. If I enable just silent editing in a GPO, the sig will create but not go as default - how do i get around this?
-- If I've run the script before with a sig name of X unless I change the name to Y it wont work again - is there a way to get it to force overwriting any variables/files/regkeys that are already there.
My first thought to resolve the first point was to use a variant of 'runas' however wouldn't that then return the AD properties for the 'runas' user rather than the user whos logging on?
& as a final point assuming the first two get resolved, is there a way to change the output of the powershell script so that it doesn't show a mountain of code, just a few steps saying "doing XYZ", "now doing ABC", ect; ?
Thanks in advance all and i appreciate any help you can give me with this.
Code:
#Custom variables
$CompanyName = ‘COMPANY_NAME’
$DomainName = ‘COMPANY_DOMAIN’
$SigSource = “UNC_TO_SOURCE”
#Settings - Customisable
$ForceSignatureNew = ’1' #When the signature are forced the signature are enforced as default signature for new messages the next time the script runs. 0 = no force, 1 = force
$ForceSignatureReplyForward = ’1'
#When the signature are forced the signature are enforced as default signature for reply/forward messages the next time the script runs. 0 = no force, 1 = force
#Environment variables
$AppData=(Get-Item env:appdata).value
$SigPath = ‘\Microsoft\Signatures’
$LocalSignaturePath = $AppData+$SigPath
$RemoteSignaturePathFull = $SigSource+’\'+$CompanyName+’.docx’
#Get Active Directory information for current user
#Active Directory Variables
$UserName = $env:username
$Filter = “(&(objectCategory=User)(samAccountName=$UserName))”
$Searcher = New-Object System.DirectoryServices.DirectorySearcher
$Searcher.Filter = $Filter
$ADUserPath = $Searcher.FindOne()
$ADUser = $ADUserPath.GetDirectoryEntry()
$ADDisplayName = $ADUser.DisplayName
$ADEmailAddress = $ADUser.mail
$ADTitle = $ADUser.title
$ADTelephoneNumber = $ADUser.TelephoneNumber
$ADFax = $ADUser.facsimileTelephoneNumber
$ADMobile = $ADUser.mobile
$ADWebPage = $ADUser.wWWHomePage
#Setting registry information for the current user
$CompanyRegPath = “HKCU:\Software\”+$CompanyName
if (Test-Path $CompanyRegPath)
else
{New-Item -path “HKCU:\Software” -name $CompanyName}
if (Test-Path $CompanyRegPath’\Outlook Signature Settings’)
else
{New-Item -path $CompanyRegPath -name “Outlook Signature Settings”}
$SigVersion = (gci $RemoteSignaturePathFull).LastWriteTime #When was the last time the signature was written
$ForcedSignatureNew = (Get-ItemProperty $CompanyRegPath’\Outlook Signature Settings’).ForcedSignatureNew
$ForcedSignatureReplyForward = (Get-ItemProperty $CompanyRegPath’\Outlook Signature Settings’).ForcedSignatureReplyForward
$SignatureVersion = (Get-ItemProperty $CompanyRegPath’\Outlook Signature Settings’).SignatureVersion
Set-ItemProperty $CompanyRegPath’\Outlook Signature Settings’ -name SignatureSourceFiles -Value $SigSource
$SignatureSourceFiles = (Get-ItemProperty $CompanyRegPath’\Outlook Signature Settings’).SignatureSourceFiles
#Forcing signature for new messages if enabled
if ($ForcedSignatureNew -eq ’1')
#Set company signature as default for New messages
$MSWord = New-Object -com word.application
$EmailOptions = $MSWord.EmailOptions
$EmailSignature = $EmailOptions.EmailSignature
$EmailSignatureEntries = $EmailSignature.EmailSignatureEntries
$EmailSignature.NewMessageSignature=$CompanyName
$MSWord.Quit()
#Forcing signature for reply/forward messages if enabled
if ($ForcedSignatureReplyForward -eq ’1')
#Set company signature as default for Reply/Forward messages
$EmailSignature.ReplyMessageSignature=$CompanyName
$MSWord.Quit()
#Copying signature sourcefiles and creating signature if signature-version are different from local version
if ($SignatureVersion -eq $SigVersion){}
else
#Copy signature templates from domain to local Signature-folder
Copy-Item “$SignatureSourceFiles\*” $LocalSignaturePath -Recurse -Force
$ReplaceAll = 2
$FindContinue = 1
$MatchCase = $False
$MatchWholeWord = $True
$MatchWildcards = $False
$MatchSoundsLike = $False
$MatchAllWordForms = $False
$Forward = $True
$Wrap = $FindContinue
$Format = $False
#Insert variables from Active Directory to rtf signature-file
$fullPath = $LocalSignaturePath+’\'+$CompanyName+’.docx’
$MSWord.Documents.Open($fullPath)
$FindText = “DisplayName”
$ReplaceText = $ADDisplayName.ToString()
$MSWord.Selection.Find.Execute($FindText, $MatchCase, $MatchWholeWord, $MatchWildcards, $MatchSoundsLike, $MatchAllWordForms, $Forward, $Wrap, $Format, $ReplaceText, $ReplaceAll )
$FindText = “Title”
$ReplaceText = $ADTitle.ToString()
$FindText = “MobileNumber”
$ReplaceText = $ADMobile.ToString()
$FindText = “OfficeNumber”
$ReplaceText = $ADTelephoneNumber.ToString()
$FindText = “Website”
$ReplaceText = $ADWebPage.ToString()
$FindText = “FaxNumber”
$ReplaceText = $ADFax.ToString()
$MSWord.Selection.Find.Execute(“Email”)
$MSWord.ActiveDocument.Hyperlinks.Add($MSWord.Selection.Range, “mailto:”+$ADEmailAddress.ToString(), $missing, $missing, $ADEmailAddress.ToString())
$MSWord.ActiveDocument.Save()
$saveFormat = [Enum]::Parse([Microsoft.Office.Interop.Word.WdSaveFormat], “wdFormatHTML”);
[ref]$BrowserLevel = “microsoft.office.interop.word.WdBrowserLevel” -as [type]
$MSWord.ActiveDocument.WebOptions.OrganizeInFolder = $true
$MSWord.ActiveDocument.WebOptions.UseLongFileNames = $true
$MSWord.ActiveDocument.WebOptions.BrowserLevel = $BrowserLevel::wdBrowserLevelMicrosoftInternetExplorer6
$path = $LocalSignaturePath+’\'+$CompanyName+”.htm”
$MSWord.ActiveDocument.saveas([ref]$path, [ref]$saveFormat)
$saveFormat = [Enum]::Parse([Microsoft.Office.Interop.Word.WdSaveFormat], “wdFormatRTF”);
$path = $LocalSignaturePath+’\'+$CompanyName+”.rtf”
$MSWord.ActiveDocument.SaveAs([ref] $path, [ref]$saveFormat)
$saveFormat = [Enum]::Parse([Microsoft.Office.Interop.Word.WdSaveFormat], “wdFormatText”);
$path = $LocalSignaturePath+’\'+$CompanyName+”.txt”
$MSWord.ActiveDocument.SaveAs([ref] $path, [ref]$SaveFormat::wdFormatText)
$MSWord.ActiveDocument.Close()
$MSWord.Quit()
#Stamp registry-values for Outlook Signature Settings if they doesn`t match the initial script variables. Note that these will apply after the second script run when changes are made in the “Custom variables”-section.
if ($ForcedSignatureNew -eq $ForceSignatureNew){}
else
{Set-ItemProperty $CompanyRegPath’\Outlook Signature Settings’ -name ForcedSignatureNew -Value $ForceSignatureNew}
if ($ForcedSignatureReplyForward -eq $ForceSignatureReplyForward){}
else
{Set-ItemProperty $CompanyRegPath’\Outlook Signature Settings’ -name ForcedSignatureReplyForward -Value $ForceSignatureReplyForward}
else
{Set-ItemProperty $CompanyRegPath’\Outlook Signature Settings’ -name SignatureVersion -Value $SigVersion}
