Powershell Help
27 Sep 2004
The Ledge Beyond The Edge
Hi,
I'm trying to run a powershell script that checks the free space on server drives and only reports back on ones with more than 75% used. I can get it to report the information from the drives, but i can't get it to filter on anything over 75% or sort it.
Here is the function i have
Code:
Function GetDiskSpace
    Foreach ($s in $servers)
        $FreeGB = @{Name="FreeSpace(GB)";expression={[math]::round(($_.FreeSpace / 1073741824),2)}}
        $TotalGB = @{Name="Capacity(GB)";expression={[math]::round(($_.Capacity/ 1073741824),2)}}
        $UsedGB = @{Name="Volume Used(GB)";expression={[math]::round(($_.Capacity/ 1073741824) - ($_.FreeSpace / 1073741824),0)}}
        $UsedPerc = @{Name="Used %";Expression={[math]::round((((($_.Capacity/ 1073741824) - ($_.FreeSpace / 1073741824)) / ($_.Capacity / 1073741824)) * 100),0)}}
        Get-WmiObject -Class win32_volume -cn $s  |
        Select-Object @{LABEL='Comptuer';EXPRESSION={$s}},driveletter, label,$FreeGB, $TotalGB,$UsedGB,$UsedPerc
    } #end foreach $s
I have tried running an additional pipe after the select-object with
Code:
where-object { $UsedPerc -gt 75 }
But it errors with Cannot compare "System.Collections.Hashtable" because it is not IComparable.
Any tips please?? :)
You've got a typo in the select-object line: Computer, not Comptuer. And shouldn't the Get-WmiObject command be at the start of the loop rather than the end?
The computer was just a label so not really bothered.
Anyway, i have changed it totally to the following
Code:
Function DiskSpace
    Get-WmiObject -ComputerName SERVER1-Class Win32_volume |
    Sort-Object  @{Expression={'{0:P0}' -F (1 -  ($_.FreeSpace/$_.Capacity))}}  |
    ft DriveLetter,
       Label,
       @{Label="Server";Expression={$_.SystemName}},
       @{Label="Free (GB)";Expression={'{0:N0}' -F ($_.FreeSpace/1GB)}},
       @{Label="Used (%)";Expression={'{0:P0}' -F (1 -  ($_.FreeSpace/$_.Capacity))}}
DiskSpace
But now my sort-object is showing the order as 1,10,2,20 etc instead of 1,2,10,20
Is there a way i can sort that on the fly?
I tried doing the following
Code:
Sort-Object  @{Expression={'{0:P0}' -F (1 -  ($_.FreeSpace/$_.Capacity)).toint32()}}
but it didn't like it :(
Probably better ways of doing it but I like to keep things as easy to read as possible!
Can export the second array $OverLimit as it should have any drivers over 75%
Assumes the account running has permission to access the servers. If not will need to use the -credential parameter which is commented out at the moment.
Also ignores the A and D drives for what it's worth!
Code:
$ServerList = Get-Content -Path "C:\Scripts\DiskSpace\ServerList.txt"
$DriveList = @()
$OverLimit = @()
ForEach ($Server in $ServerList)
    $Disks = Get-WmiObject Win32_LogicalDisk -ComputerName $Server #-Credential $Cred
    ForEach ($Disk in $Disks)
        If ($Disk.DeviceID -Ne "A:" -And $Disk.DeviceID -Ne "D:")
            $Row = "" | Select ServerName, DeviceID, VolumeName, Size, FreeSpace, Used, UsedPercentage
            $Row.ServerName = $Server
            $Row.DeviceID = $Disk.DeviceID
            $Row.VolumeName = $Disk.VolumeName
            $Row.Size = [Math]::Round($Disk.Size / 1GB, 2) #Convert to gb
            $Row.FreeSpace = [Math]::Round($Disk.FreeSpace / 1GB, 2) #Convert to gb
            $Row.Used = $Row.Size - $Row.FreeSpace
            If ($Row.Used -gt 0)
                $Row.UsedPercentage = [Math]::Round(100-(($Row.FreeSpace/$Row.Size)*100), 2)
            $DriveList += $Row
$OverLimit = $DriveList | Where {$_.UsedPercentage -Gt 75}
$DriveList | Format-Table -AutoSize
$OverLimit | Format-Table -AutoSize
