Powershell script to create user, mailbox and put into AD group
Man of Honour
20 Sep 2006
I know there's loads of examples around the net, but I'm wondering if someone knows of or has access to a basic one? Environment is 2012R2 with Exchange 2016 and just a couple of groups in AD.
Thanks.
Hi Chris,
Here is one I created for use at work:
#this script creates a staff user and enables their mailbox
Import-Module ActiveDirectory
Add-PSSnapin Microsoft.Exchange.Management.Powershell.E2010
$UserFirstname = Read-Host -Prompt 'Input first name'
$UserSurname = Read-Host -Prompt 'Input surname'
$Password = Read-Host -Prompt 'Input password'
$Dept = Read-Host -Prompt 'Input department'
$Title = Read-Host -Prompt 'Input job title'
$FirstLetterFirstname = $UserFirstname.substring(0,1)
$SAM = $FirstLetterFirstname + $Usersurname
$DisplayName = $FirstLetterFirstname + " " + $UserSurname
$FullName = $UserFirstname +" " + $UserSurname
$Profilepath = "\\college.local\sysvol\college.local\Shared Profiles\Staff"
$UPN = $SAM + "@college.org"
$OU = "OU=New Staff,OU=Staff,DC=college,DC=local"
$NewOU = "OU=Teachers,OU=Staff,DC=college,DC=local"
New-ADUser -Name $FullName -givenName $UserFirstname -surname $UserSurname -SamAccountName $SAM -UserPrincipalName $UPN -DisplayName $DisplayName -AccountPassword (ConvertTo-SecureString $Password -AsPlainText -Force) -Enabled $true -Path $OU -ChangePasswordAtLogon $true -ProfilePath $Profilepath -Department $Dept -Title $Title
Start-sleep -s 5 #allow time for replication
Write-Host " "
Write-Host "$SAM has been created"
Get-ADUser $SAM | ForEach-Object {Add-ADGroupMember -Identity 'Group 1' -Members $_ }
Get-ADUser $SAM | ForEach-Object {Add-ADGroupMember -Identity 'Group 2' -Members $_ }
Get-ADUser $SAM | ForEach-Object {Add-ADGroupMember -Identity 'Group 3' -Members $_ }
Get-ADUser $SAM | ForEach-Object {Add-ADGroupMember -Identity 'Staff' -Members $_ }
Get-ADUser $SAM | ForEach-Object {Add-ADGroupMember -Identity 'Teach' -Members $_ }
Write-Host " "
write-Host "User has been added to the default groups"
Start-Sleep -s 5 #allow time for replication
Enable-Mailbox $SAM
Get-ADUser $SAM | Move-ADObject -TargetPath $NewOU
Write-Host " "
Write-Host "$SAM moved to $NewOU..."
Write-Host " "
Write-Host "Copy this to the Staff members S drive: \\college.local\data\staffdata\teachers\$SAM\Documents"
Write-Host " "
write-Host "User also needs to be added to the relevant email groups"
Legend.
If I wanted firstname.lastname as the SAM and lastname, firstname as the DisplayName would I do:
$SAM = $UserFirstname + "." + $UserLastName
$DisplayName = $UserLastName + "," + " " + $UserFirstName
Legend.
I haven't tested it but that looks exactly right to me.
Though you could probably save a bit of code for display name and add the space after the comma, so:
$Displayname = $UserLastName + ", " + $UserFirstName
But as I've said I haven't tested this - so let us know how you get on.
Thanks,
Danny
Ah, thanks.
Not working right now as it looks to be a little different with Exchange 2016, you can't just add a PSSnapin anymore.
Might build a home lab and do some experimenting.
You can sometimes avoid the + thing totally, powershell does let you use vars in strings like this:
$FirstName = "Bill"
$LastName = "Hats"
"$FirstName.$LastName"
"$FirstName, $LastName"
The uri is the fully qualified domain name of the exchange server, so if your exchange server was 'srv-exchange' and your domain was 'college.local' then the fqdn would be 'srv-exchange.college.local'
That's what I thought, but it's not working.
$FirstName = "Bill"
$LastName = "Hats"
Nice tip, thanks.
Thanks HungryHippos, I'll keep that in mind!
Chris, what happens when you try it?
You could always run it line by line in non-ise powershell and see what happens.
The first line should popup and ask for domain credentials
The second line will create the session
The third line should enter you into the session
Thanks,
Danny
Silly me, I had an = in front of the uri. No idea where that came from. On another error now, I need to develop this at home or on Azure a bit more I think.
