PPD for GTX 650ti
20 Nov 2012
east cost Lincolnshire
As when i was looking on the net for PPD for this card and i found no recant info i think i will post my findings now that its coming up to a week that i have been folding on it ...i have been getting 8070 and 8071 WU and its been averaging 17000 to 17500 PPD running 24/7 ..its the stranded EVGA card at 928mhz which i have got to 992mhz over the week.. this is still much less than some of the factory OC
so probably Representative of the breed..
Temps.. i get it cheap as had a broke fan blade, it now has a cheap standard 80mm x 25mm case fan with the fan shroud removed..the fan has no noise at 100% and keeps it at 52 to 55c
CPU is a Athlon ii 235e OC to 3400mhz also folding (it made no noticeable difference if the CPU was folding @ 100% or not)
My GTS450 got 12500 to 13000 PPD in the same rig
Hope this is of help
I had a 2GB Gigabyte oc version which would peak at 20k PPD but 18K was more normal so pretty close to what you're getting.
