PPD too low from second system - Help please?
Caporegime
29 Jul 2011
In acme's chair.
Hi guys, some of you might have seen me mention this elsewere, but I have a system used mainly for folding which has an i7 930 and a GTX570. Combined they are only pulling between 18K and 25K.
Now I ran the GTX570 in a different system before on Core17 and it was getting around 40K PPD, and I have heard from elsewhere that the i7 should be getting around 20K PPD. I have a passkey configured, the slot rules etc are configured correctly, I have ran quite a-lot of WU's on the system now so I believe I have easily surpassed the minimum quota for bonus points.
I have also re-installed the client a couple of times, changed various slot settings about, and of-course re-started the actual system several times.
It is not running in power saver mode, everything it optimised for high performance, the CPU and GPU seem to perform fine for everything else thought I will explore that more extensively if this continues.
Anyone have any ideas? :(
OS is Windows 8 Pro x64, full specs:
i7 930 @ stock
Asus ROG Rampage II Extreme
8GB (2x 4GB) Corsair Vengeance Blue 1600MHz (at 1066MHz because I need to change it in the BIOS)
GTX570 DCUII 1.25GB @ stock
500GB Barracuda 7200.9
Cooling is decent, PC-K62 with a 140MM intake at the front, 2x 140MM exhausts in the top, Kuhler 620 pulling air in at the back through a filter, and of course the DCU-II cooler on the 570.
have you tried to fold on both cpu and gpu on there own to see if both running is causing the problem
also have you tried any different drivers for the gpu.
is both cpu and gpu showing 99% load while they are folding?
oh ye - you deffantly have the " client-type" " advanced " in the gpu slot , nothing misspelt by mistake or missing a letter?
Are you reserving one core to feed the gpu?
I believe the CPU is running on 7 threads. Should I change it to 6 so that the GPU has a full core?
CPU slot has no rules, GPU slot has client-type advanced and next-unit-percentage 100.
CPU is running at 99%, GPU is running at 95 - 99%. When using the CPU on its own it only pulls about 7 - 9K PPD which is an issue on its own. The GPU on its own only pulls 12 - 15K PPD which again is an issue on its own.
I have not tried backdating drivers, but it has had two driver updates since which have made no difference.
next-unit-percentage 100 isn't needed , you can remove that.
what work units are giving you poor ppd? the last 3 days or so my cpu has showed poor ppd, 7/8k ppd [email protected] , my gpu is also been funny aswell on some units
when I had NVidia gpus they was always at 99% when folding,
RUNNING cpu:8 , if its not changed then try it at 7
03:54:48:WU02:FS00:0x17:Project: 7811 . even my 7950 was getting really rubbish ppd with these, yet while searching most others were get really good ppd , I changed the drivers and it seems to e back to normal now 90k ppd
changing the cpu slot to 6/7 and leave it a while to work its self out and see what ppd it gives you then
Changed. Well spotted. :) Cheers.
Will see if it helps.
I thought it was on 7 threads.
That may help the cpu scoring but it won't do anything for the gpu. What monitoring do you have on the GPU? What core clock is it running at? A tool such as Afterburner will tell you clocks, temps, etc.
Clocks and temps etc are all in check, using GPU-Z & Afterburner.
It should help the gpu as well, as with Nvidia and Core 17 it uses an entire core of the cpu for each GPU
acme are you just running the one rig? Your daily points are around the 110-120K PPD mark which sound about right.
I cant belive how much gtx570 & 580 are now :o , infact if you get 40k on a 570 what would a 580 do? theres some refurbs for VERY cheap if you scan around :o
I am running the 670 in my sig rig for perhaps 18 - 20 hours a day, and the i7 930 and GTX570 24/7.
The 670 pulls 75 - 85K.
So are you thinking that the rig is in-fact making the PPD that it should, but the app isn't reporting it correctly?
My points in the last 24 hours is 86K according to extreme overclocking stats.
I did some scanning around and the prices don't look particularly interesting.
Yes its dropped to 17,500... :rolleyes:
*edit* Oop and gone back up to 23K again, which is where it was before.
what work unit is it?
did you remove the next-unit-percentage 100 , i know you don't need it so weather it'll make any difference i don't know, but seeing as you don't need to have it, its worth removing it and trying to see if i does anything
also drivers, seeing as there is no idea as to what it is, its worth trying everything though right? :D
oh ye, is your gpu overclocked?
edit - you say you had 40k before , but was this using windows 8 or 7?
after looking at that log,it was refused connection so many times, now i really have no idea but, you have to complete 80% of WU to get the points bonus, would all these connection attemps be classed as a " fail " and knocking you below the 80% rate needed? just a wild stab here , no dout i am totally incorrect.
Remember its not how long it takes to fold the WU its the total time taken from download to upload.
