Pre-Applied Thermal Compound
19 May 2004
Horsham, West Sussex
Have one of these
https://www.overclockers.co.uk/showproduct.php?prodid=HS-050-AR
In the past I have tended to clean off pre-applied thermal compound and apply my own because
1 - the pre-applied stuff wasn't that good
2 - it was probably too thick
But that was a few years ago.
Have thing moved on - is it now best to use pre-applied or still scrape off and use your own?
Cheers,
Nigel
You'll probably feel happier if you do it yourself.
But it won't make a meaningful difference.
Money is better spent on a bigger cooler and still using the supplied paste.
Usually depends on the type of thermal paste that was pre-applied.
A 4g syringe of aftermarket thermal paste would last you a few years if you wanted to apply your own, depending on how often you would be removing the heatsink from your build.
Removing - hopefully not at all.
The pre-applied stuff is MX-4
I have a syringe of MX-4
So it really comes down to whether the pre-applied stuff is too thick - but it sounds like I would be best just using it as it is.
Cheers,
Nigel
