Pre Braided Cables
Unfortunately ocuk dont stock mixed coloured cables, just the bitfenix range, whilst available in a large range of colours, they dont manufacture mixed coloured ones.
Already looked , but what i am after is a 24pin atx cable in black and red , cant find mixed colors anywhere :( and i really dont have the patients to do it myself
I think most of the mix coloured ones you see in case pics are DIY jobs. I did attempt a 24 pin extension braid myself and it was a right nuisance despite looking decent at the time. In the end though one of the pins broke so I just threw it away, wish I'd just bought an extension in the first place! If you decide to rebraid an extension yourself make sure you buy one of the proper tools to remove the connections without breaking anything :)
ive done it before , and it was loooooong , just cant be bothered at the mo , just wanted to get some to match my radeons and maximus v formula when it arrives :)
Shakmods is a company that produce mixed colours.
Could just buy a black and a red and swap over the cables as desired. You'd then have two mixed colour ones an could possibly sell one on.
I use a couple of straightened staples to remove the terminals. It's easy provided the staples are too soft and pliable.
There are a few sellers on ebay that do mixed colours good quality too.
Got my blue ones of a seller there as the bit fenix ones on ocuk didn't match the mayhems berry blue that well.
