Hello, in the next few weeks i'm planning on building a new LGA2011 machine. Primarily being used for gaming.
So far I am thinking on purchasing these items :
Ram £95 -
http://www.overclockers.co.uk/showproduct.php?prodid=MY-064-GS&groupid=701&catid=8&subcat=813
SSD £100 -
http://www.overclockers.co.uk/showproduct.php?prodid=HD-009-CR
Motherboard £275 -
http://www.overclockers.co.uk/showproduct.php?prodid=MB-487-AS
Processor £240 -
http://www.overclockers.co.uk/showproduct.php?prodid=CP-391-IN
Case £280 -
http://www.overclockers.co.uk/showproduct.php?prodid=CA-249-CM
Windows 7 ultimate £60 -
http://www.software4students.co.uk/Microsoft_Windows_7_Ultimate_64_bit_Edition_Upgrade-details.aspx
Graphics card -
(SLI) £650 - http://www.overclockers.co.uk/showproduct.php?prodid=BU-000-KF&groupid=701&catid=1914&subcat=2294
(Single) £330 - http://www.overclockers.co.uk/showproduct.php?prodid=BU-000-KF&groupid=701&catid=1914&subcat=2294
I also need to choose a screen, any advice would be appreciated. It needs to be around £150, £200 at a stretch. I do plan to buy other monitors later down the line though. So I would like them to be all of the same model.
Overall i'm expecting to spend around £1500, less would be better of course. My questions are as follows :
1) Shall I stick with LGA2011, is it worth it?
2) Should I buy the Cosmos II, for the price would there be another case which would maybe suit me better. I know the Cosmos is very large and has great potential. But as of now, I have no intention on using water cooling.
3) Graphics cards have been giving me a headache, as i'm unsure which to buy. I have read that unless you go to 3X SLI, then there is no point in buying the 4gb VRAM cards. But I am unsure. I was thinking of buying a single 670 and then later down the line either go into SLI or purchase a newer model of card.
4) Cooling is another thing I am really unsure about, so any help in that respect would be useful. (I'll read around on the forum if not).
Other than that I am just in need of an observers opinion, if you could give me any other alternatives I would really appreciate it. Thanks in advance ~
Ram £95 -
SSD £100 -
Motherboard £275 -
Processor £240 -
Case £280 -
Graphics card -
